| Help! Tuyau du carburateur? | |
Sova De passage
  Nombre de messages : 38 Localisation : Czech republic Date d'inscription : 18/01/2010
 | Sujet: Help! Tuyau du carburateur? Ven 10 Mai - 19:25 | |
| Hello Im speaking only english... Please what is this tube from carburettor and where has been connect?  I dont have connect this tube from beyond sorry for my english...im from Czech republic, renault 11 turbo owner hello to France! |
 | Sujet: Re: Help! Tuyau du carburateur? Sam 11 Mai - 16:51 | |
| Hi Sova,
Could you take a wide picture please ? I don't see where is situated your tube. What's your engine ? Do you have air conditioning?
Sova De passage
 | Sujet: Re: Help! Tuyau du carburateur? Sam 11 Mai - 21:59 | |
| Hello It´s C1J 760 Here is wide photo...i dont know where connect this tube...:-/ Thats Renault 11...28 years old...this car dont have air conditioning.  Thank you |
Fred6359 Débutant
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 8:34 | |
| c pas le tuyau de depression qui va sur l'aei sa?? |
Fred6359 Débutant
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 8:38 | |
| si si c bien sa c le tuyau que va sur le boitier électronique d'allumage (petite capsule noir) |
Sova De passage
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 11:40 | |
| sorry but i dont know french...and google translate is very poor for french-czech translation Both languages are difficult in sentences composition... |
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 14:09 | |
| It's strange! With my docs, for engine C1J 760, your tube must be connected on the turbo's wastegate. But, on your picture you have a another tube already connected on the wastegate. Have you changed something before? As Fred says, your tube may be connected on the AEI's vacuum unit. Have you some problems with your turbocharger (pressure/ triggering) ? _________________ "If in doubt, Flat out" Colin McRae
Sova De passage
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 15:35 | |
| I dont think so...All is Ok with turbocharger pressure I forgot said...car, engine running fine...i think... Only i was surprised, those tube doesnt connect nowhere |
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 16:06 | |
| Have you a tube connected on the vaccum unit (AEI) ? _________________ "If in doubt, Flat out" Colin McRae
Sova De passage
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 16:28 | |
| - Dje a écrit:
- Have you a tube connected on the vaccum unit (AEI) ?
Sorry but i dont know what is it I've never heard about it before (AEI) What that a where I find this? I thought you talked about climatisation... |
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 16:45 | |
| Oh sorry, AEI it's french... that's means "Allumage Électronique Intégral".  On this picture you can see the "AEI" on my car. The tube is connect to the small nozzle (broken on this picture). Ok for you now ? Do you have a tube connected here ? |
Sova De passage
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 16:50 | |
| Oh..i understand now! In english its probably called "Ignition Module" Yes i have connect that tube, which u showing me here... This is other tube about I talking |
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 17:02 | |
| Yep, ignition module in english.
So the tube connected here, where he went? _________________ "If in doubt, Flat out" Colin McRae
Sova De passage
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 17:54 | |
| yes, tube is connected on the vaccum unit...
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 18:01 | |
| Hello, this is not your overflow tube is a tube that is connected to nothing and placed above the gearbox .. |
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 18:05 | |
| - Guigui69.69 a écrit:
- Hello, this is not your overflow tube is a tube that is connected to nothing and placed above the gearbox ..
Du coup son branchement de la wastegate est bon alors ? Et il sert a quoi ce tuyau ? Mise à l'air libre ? |
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 18:17 | |
| Sa wastegate est ok, c'est en cas où il y a une trop grosse arrivée d'essence, le trop part par là.. |
Sova De passage
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 18:20 | |
| oh im surprising how simply thats it... so...simply this tube is not connected for nothing? very surprising and very funny solved problem Very Thanks friends from France! |
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 18:32 | |
| Nothing, but do not let the tip above a heat source because if gas release, the fire insured .. Place the tip over the box .. |
Sova De passage
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 18:44 | |
| Ok, Very thanks for your suggestion |
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 18:54 | |
| Y're welcome ! Par contre Guigui, pourquoi sur mes docs il branche ce tuyau sur la wastegate ? Grosse difference entre le C1J 760 et C1J 770, sur le 770 la wastegate est a double effet. De même les refs des carbu entre ces 2 moteurs sont différentes. _________________ "If in doubt, Flat out" Colin McRae
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 19:14 | |
| Car tu as deux montages entre phase 1 et 2.. |
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 19:20 | |
- Car tu as deux montages entre phase 1 et 2..
Ça je m'en doute bien, sur le 760 on voit bien sur le schéma que le tuyau commande la wastegate. Bref je connais pas assez bien la version turbal, jvais finir par en chopper une rien que pour me former |
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 19:24 | |
| Bonne idée.. |
Fred6359 Débutant
 | Sujet: Re: Help! Tuyau du carburateur? Dim 12 Mai - 20:04 | |
| et en resumé pour ma pomme vous racontez quoi? |
 | Sujet: Re: Help! Tuyau du carburateur?  | |
